Lift lever question
Bob Spooner
03-25-2004 04:41:31
All,
I'm refurbishing my 1955 960. I am right now working on the lift. I notice that the lever (touch control lever maybe) that you raise and lower the 3 pt with looks wierd. Mine has a little dog-leg to it. Perhaps 10-15 degrees. It looks maybe like it was bent and re-welded in a previous life. Perhaps someone was trying to shortcut the lift mechanism rebuild. Hard to say. Is this lever supposed to be straight?
Thanks.
Bob
East Hampton, CT
Mark
03-25-2004 05:42:40
 Re: Lift lever question in reply to Bob Spooner, 03-25-2004 04:41:31
All that I have seen have a slight angle outward favoring the top (as I recall). They tend to favor the outboard guard which is where you put your stops. That way you just slide the lever up or down and it hits the stop for preset (you set) limited lift range, but if you need the full lift range, you just pull it to you and slide by the stop going for the end of the stroke.
Mark
