whats the difference?
Andy in Ohio
03-27-2004 15:00:22
Just wondering what is the difference between a 9-N and a 2-N? thank you, Andy
Jim.UT
03-27-2004 20:25:06
 Re: whats the difference? in reply to Andy in Ohio, 03-27-2004 15:00:22
Read this:
Charles (in GA)
03-27-2004 19:31:46
Others will explain in more detail but the 2N, being a wartime model was built as skimpy as possible. Most of them apparently had a magneto ignition, which eliminated the battery, generator, and starter and most of the wiring. The shortage of rubber also caused Ford to produce many of them with all metal wheels without tires.
Charles
Larry NCKS
03-27-2004 15:53:43
Not sure of all of them, however the 9N was built from 39-42. The 2N replaced it in 42 and was built until the 8N replaced it in 48. Maybe someone else can enlighten us on the refinements that defined the 2N over the 9N. I know the 8N, as compared to the 9N, was like going from a Ford to a Lincoln.
