Ok, I'm waiting. I will follow the post as it gets farther and farther back. You don't have to re-post it for me to find it. But, in the mean time. Now that I know your tractor series, I am confused about something. My 1000 series blue is supposed to be just like your 100 series red and gray, except for the paint. The 4 speed transmission on my 2000 (600 series copy) and 4000 (800 series copy)have a starting safety switch mounted in the cover of the transmission. You can't miss it. There are three things in the cover: gear shift lever, fill plug, and this switch. With the key on, 12v is applied to the starter solenoid (small terminal)regardless of whether you want to start or not. The low side of this primary circuit (inside the sole. housing) connects to a second small terminal. You will initially measure 12v on that one too....that is until you depress that switch on top of the tranny. That grounds the primary ckt.low side putting 12v ACROSS the primary (starting) coil and the solenoid energizes sending batt voltage to the starter hot terminal. That switch forces you to have the transmission in neutral to start the tractor. In this setup, they only use a single pole single throw switch (SPST) and it is either ON or OFF. There is no START positon, just OFF and ON. The ignition switch sends 12v to everything in the ON position. So ignition gets juice, your light switch can get juice (unless it is wired to the 12v input to this switch which allows lights with the ign. key off as you mentioned)and you have juice to your starter solenoid (but no ground until you want it via the transmission safety switch). If you have a key switch with a start position, someone has slipped you a "mickey". With this setup, you don't have 12v to the sole. until you put the ign sw in START plus you still have the tranny switch open so you have to hold the START and push down on the safety sw to get juice to the starter....unless someone wired around your safety switch when they installed the key start switch. Let me know. But that still doesn't explain why, when you jumped from the batt hot term directly to the starter hot term with a batt hookup wire (biggun) nothing happened. But we'll get there. This is like a Mickey Spilane mystery. Still think there are 2 foxes to chase. Mark (er ah txblu)
