Order Ford NAA Parts Online
Did the Jubilee have live pto?
Ray
03-30-2004 17:40:38
I see several jubilee tractors advertised with
live pto,I've owned a few and never saw one with live.
Jim.UT
03-31-2004 08:20:42
 Re: Did the Jubilee have live pto? in reply to Ray, 03-30-2004 17:40:38
The dealer added optional live pto as mentioned below is hard to find because they tended to have problems and there are no replacement parts available. Here are some pics I took of the pump and pto lever on a junkyard NAA equipped with the live option.
third party image
This shows the add-on pump mentioned below. It's the silver colored thing and has a proofmeter drive on the end.
third party image
This shows one view of the live pto selector handle. You can also see a thin hydraulic line that runs from the cover, up over the trans to the aux pump pictured above. It's about the size of automotive brake line.
third party image
Just another view (from the top) of the handle.
mikeinmo
03-30-2004 17:50:08
NO! If it is a true Jubilee is doesn't have live PTO. Has to have the five speed transmission to have live PTO I think. Some of the later 600 series had this but not the Jubilee.
Don in Fl
03-30-2004 18:20:46
 Re: Re: Did the Jubilee have live pto? in reply to mikeinmo, 03-30-2004 17:50:08
Yes... There was a option from Dearborn that allowed the Jubilee to have Live PTO
RICKWI
03-30-2004 18:49:25
 Re: Re: Re: Did the Jubilee have live pto? in reply to Don in Fl, 03-30-2004 18:20:46
The option was a hydraulic clutch pack which went between the trans and diff to disengage the drive line without stopping the PTO. It had it's own small pump mounted between the real pump and the tachometer drive. Actuated by a longer handle in the left side PTO lever cover.
NCJohn
03-31-2004 05:56:11
 Re: Re: Re: Re: Did the Jubilee have live pto? in reply to RICKWI, 03-30-2004 18:49:25
That's correct, Rick. I have an original 53 Jubilee (4 speed) with the Dearborn live pto option, and it is just as you describe. With this feature, you can be mowing along and move the lever back effectively disengaging the trans from the driveshaft but contininuing to transfer power to the pto. Slide the lever forward and off you go again. Pretty neat.
mikeinmo
04-01-2004 19:31:18
 Re: Re: Re: Re: Re: Did the Jubilee have live pto? in reply to NCJohn, 03-31-2004 05:56:11
I stand corrected, been around red belly fords for forty years now never seen one with the "lever" you are talking about to get "live" PTO out of a 4-speed. Guess them newfangled gadgets haven't made it to the Missouri hills here. Only tractors in these parts with a lever to stop the tractors travel while the PTO is running is what I believe they call an Allis Chalmers.
