Order Ford 4000 Parts Online
1964 Ford 4000 3 point hitch comes up half way an
Alex Kollmar
04-06-2004 12:41:59
The three point hitch comes up half way. The speed is fast and no unusual noises when one raises it.
Wayne
04-07-2004 14:55:44
 Re: 1964 Ford 4000 3 point hitch comes up half wa in reply to Alex Kollmar, 04-06-2004 12:41:59
If you do a search in the achrives for Zane Sherman; he has a kit that includes a "cam follower pin" and the necessary gauges and instructions on how to adjust your lift. The most likely culprit is the cam follower pin, which when worn will result in the lift not lifting fully.
Lee
04-07-2004 13:49:49
That sounds like an adjustment problem. If I knew how I'd explain how to fix it but if it were mine I'd have to get a manual and see if I could figure it out. You may want to try searching the archives here and see if someone has posted information that will help. Good Luck, Lee
