Order Ford 3000 Parts Online
What is a Ford 3000 Diesel worth?
Adam
04-13-2001 05:23:54
As you may have seen my last posting regarding the 3 point help (which I will use your advice and trouble shoot today) I picked up a Ford 3000 diesel in a package deal. The tractor is way too big for my yard and I will need to sell it. It seems to be in average to above average shape and runs good. Can someone give me a ballpark value?
Thanks
Adam
RickB.
04-14-2001 17:12:09
 Re: What is a Ford 3000 Diesel worth? in reply to Adam, 04-13-2001 05:23:54
I just went back & read your original post. If the 3PH will not lower, chances are the unload valve is stuck. Whether or not the pump is working, or a selector valve is in the right/wrong position, the hitch should drop if the quadrant lever is lowered. Sounds like the lift cover will have to come off. Where are you located, I may be interested if not too far away.
Kirkules
04-13-2001 12:26:20
Actually, I think you want to look at Tractor Values on the left column. I didn't see too many but it's a start. Other places to check would be the auction pages of both this site and other auction houses like eBay
Mike M - Tx
04-13-2001 07:01:14
Take a look at the Tractor Registry on the left side of this screen. You will find some prices there.
Regards,
Mike M - Tx
dillinrl
04-14-2001 17:48:01
 Re: Re: What is a Ford 3000 Diesel worth? in reply to Mike M - Tx, 04-13-2001 07:01:14
I live in southwestern Ohio and there is a 3000 diesel with brushmower advertised in our local paper for 5000.I believ it said it was 69 model and in good condition.
