Order Ford 860 Parts Online
860 leaking oil?
bball
04-13-2004 18:40:51
I have an 860 that is leaking engine oil I think. When I first bought it, I thought it was just the oil pan gasket because it leaks mostly from that area at the rear of the oil pan just in front of where the engine and tranny mate up. Changed that out, but it still leaks. (I'm sure it's not an oil pan leak.) However it only leaks once the engine is good and warm. It doesn't pour out, but drips pretty quickly. Once I shut the engine off, it stops. I'm pretty certain it's engine oil because after using the tractor all weekend to set fence posts, it was down a quart of oil. I had just changed all the fluids 2 weeks ago, so they are all in good shape and virtually the same color. Does anyone have an idea as to what could be causing a leak in this part of the tractor and am I going to have to split the tractor to fix the leak????
RogerC
04-13-2004 18:54:30
 Re: 860 leaking oil? in reply to bball, 04-13-2004 18:40:51
Sounds like a rear main seal leaking. Don't have to split the tractor but it can still be a real pain to replace if it's still the original rope-type seal.
