Order Ford 4500 Parts Online
4500 backhoe -- lots of information needed!!!
J.R.
04-13-2001 19:48:59
I just bought a 4500 loader-backhoe, is this tractor same as farm tractor 4000?? where do you check trans oil level and what kind of lube, in manual transmission?? looks to have filler plug, by shift lever and at top of rear end housing. swing chain has lots of slack in it, also appears that there is a linkage from swing mech. to hoe control valves that is unhooked. I plan to change hoe controls to 2stick S.A.E. type. Would appreciate any info. J.R.
Bob Burke
04-17-2001 16:41:19
 Re: 4500 backhoe -- lots of information needed!!! in reply to J.R., 04-13-2001 19:48:59
I agree on getting a manual. If you have a shuttle shift trans I think they came with a dipstick attached to the fill hole(mine was missing). Don't remove the 2 large hex bolts on the sides of trans, these are not fill holes but they do hold the shift rail in place. I found this out the hard way and the 2 spacers fell to the bottom of the trans, then it will go into 2 gears at the same time and lock up.
chuck
04-15-2001 10:25:25
4500 is a industral tractor the 4400 were called
ind. also but were the same as the farm version.
The way to tell is the 4400 has sheet metal grill
& 4500 had thick plate steel grill.The 4500 uses
80/90w fluid in the trans/rearend & should have a
square head pipe plug on the right side of
trans next to foot board.Fill up till it runs out
ethier using the big cap on the trans or the one
behind the seat on the top of the rearend.Unless
your is a automatic trans.
Tony Jacobs
04-13-2001 22:18:16
Hey J.R. , Looks like you better go the New Holland website also and order some parts books and service manuals for your tractor also . Thanks Tony Jacobs
