Order Ford 4000 Parts Online
Ford 4000
Bob
04-17-2004 15:19:57
I just purchased a Ford 4000 gas seletospeed tractor It has 4 cyinders. The numbers stamped into the bell housing are 41315 then below is a diamond with 35814 behind it.What do these numbers mean and what year is it? Thanks
Tommy D
04-19-2004 09:13:59
 Re: Ford 4000 in reply to Bob, 04-17-2004 15:19:57
Try here.....
Link
tony
04-18-2004 04:19:42
Link
then click o the link "production codes and model numbers".
Geo in SD
04-17-2004 21:02:18
I might be reading my book wrong, but 41315 is the model number. 4 means 172 cu in engine, gas or diesel. 1 means ag and ind models made in 63 or later. 31 means four wheel low center of gravity type with adjustable front axle. 5 means select-o-speed trans with hydraulic system and 540 pto. Can't find my info for the serial no., but one of the other guys here should be able to help you. 35814 is your serial number. I'm guessing it is a 64.
txblu
04-17-2004 17:53:13
Go to your NH dealer and spend $17 for an I&T manual. It'll tell you and a lot of other things you need to know too.
txblu
