Steering shaft and nut assembly
BOB
04-19-2004 05:40:26
Have a problem with my stering shaft and nut assembly on my 1964, Ford 4000. Does anyone know of a source for the split tubes that clamp to the nut for the ball bearings to circulate thru? Also does anyone know exactly how many bearings there should be in the assembly and their required diameter. Would like to fix mine due to the cost of a new assembly, if anyone has a source for the assembly, for less than $200 please share it. Thanks
Dan
04-20-2004 17:32:48
 Re: Steering shaft and nut assembly in reply to BOB, 04-19-2004 05:40:26
Hello Bob, I had to replace the steering gear(ball-nut) on my Ford 1210. I do not know if the same size is used on your 4000 but I think I can still find the tubes and bearings if you want to try.
BOB
04-27-2004 04:06:56
 Re: Re: Steering shaft and nut assembly in reply to Dan, 04-20-2004 17:32:48
Thanks Dan,
I've tried to locate a picture of the steering components in the 1210 but can't find a breakout. I would be suprised if they were the same. The tubes and bearings in mine look like the 8N and several other tractors in that vintage. If you think yours looks like what I have in mine I would like give it a try. Thanks
