Order Ford 3000 Parts Online
Clutch and hydraulic question Ford 3000 `71
Asbjørn
04-24-2004 09:51:04
Hello
My "new" 3000 is really jumpin and jerky when i release the clutch and uses the high series.
Is my tires to big? 12.4-32. its fast on the road to...and offroad low series is a must.Or could it be oil on the clutch plate?
The hydr.pump looses its prime and when the 3 p rises it jumps and if i rev the engine the lift stops until i slow down.
Thanks fom Norway
david
04-24-2004 17:52:00
 Re: Clutch and hydraulic question Ford 3000 `71 in reply to Asbjørn, 04-24-2004 09:51:04
the jerking sounds like the relief valve and the stopping when reving the engine sounds like a stopped up filter or screen; or maybe low on oil. good luck, david in texas
hvw
04-24-2004 10:19:22
Asbjorn, It sounds like your pump may need rebuilding and unless you are a professional mechanic like a lot of guys on this board you need to let a professional do it in my opinion. You'll be good to go for a lot of years. I don't know about the tires.
