ford 1210 4x4
289stude
05-17-2004 16:21:50
hi guys i have a 1986 1210 4 wheel drive i'm told it has about 16 h.p. which i think should be plenty to mowe with.My problem is when I go up hill the thing howls.I bought it used and it has always done this,(only used it about 5 times).Anyway is this normal? the hill is about a 20 foot slope at about 45 degrees.It runs perfectly otherewise. Thanks in advance for any replies.
P.S. anybody have any info. on old studebaker cars & trucks for sale?
TomG
05-18-2004 03:26:42
 Re: ford 1210 4x4 in reply to 289stude, 05-17-2004 16:21:50
If it has a hydrostatic TX the relief valve is probably opening. Use low range and let off the speed pedal to reduce ground speed.
If you are new to tractors and it has HST, the speed pedal isn't like an accelerator on a car. It's more like a continususely variable transmission. Slow speeds are low gears. Operating on anything like 45-degree slopes likely isn't recommended and there are severe safety issues. It'd be good to read about tractor stability and ballast.
289stude
05-18-2004 14:10:15
 Re: Re: ford 1210 4x4 in reply to TomG, 05-18-2004 03:26:42
IT IS AN HST. WHERE IS THIS RELEIF VALVE & HOW DO YOU FIX IT?
TomG
05-19-2004 03:30:16
 Re: Re: Re: ford 1210 4x4 in reply to 289stude, 05-18-2004 14:10:15
Sorry I won't be much help with specifics. My parts manuals cover 1210's but my repair manual doesn't. The valve must likely is on the pump body. Whether it is accessible without a major tear down I don't know. To know for sure the relief valve has a problem would take a pressure test, and procedures from a manual are needed.
There may be nothing wrong with the tractor but just that it isn't designed for that great of slope and speed. Too great of a load on an HST and the relief opens. The load can be reduced by using low range and going slow by reducing the speed pedal. I'd also check to ensure the brakes aren't dragging and I'm assuming the engine is run at PTO RPM. If that doesn't manage the problem a New Holland dealer could perform a pressure test to see if the relief setting is low. There may be other explanations for the howling as well or it may be normal. In general tractors aren't intended to work on 45-degree slopes for mechanical and safety reasons.
