Hydralic Question
Bennie
05-30-2004 06:48:52
I was bushogging with the ford 5610 when all of a sudden the lever that raises and lowers the bushhog moved. After that it is hard to move and when it does the mower goes all the way up or down. Any suggetstions on what to look at.
Charles (in GA)
05-30-2004 07:36:58
 Re: Hydralic Question in reply to Bennie, 05-30-2004 06:48:52
Sounds for all the world like you have position/draft control selection and the lever got knocked to draft (generally it should be in position for everything but plowing). In draft it will be all up, or all down, nothing in between, the load on a plow or similar will cause the tractor to raise the implement as needed.
Charles
