Order Ford 3000 Parts Online
Interchangable parts 3000 and 4000
asbjorn
05-31-2004 14:50:38
i am offerd a 4000 tractor for parts but i have a 3000, both diesels.Anyone knowing if there would be some interchangable parts ? For ex. my tractor does not have power steering but the donor have.Would it fit?
Thanks
RickB
05-31-2004 14:58:26
 Re: Interchangable parts 3000 and 4000 in reply to asbjorn, 05-31-2004 14:50:38
If the 4000 is an SU with the same radius rod swept back axle as the 3000, it will probably fit. A general purpose or row crop style 4000 will share only the power steering pump with a 3000. Transmissions may well interchange if the 3000 has live PTO. You would have to keep the clutch/flywheel with whatever rear axle it was built for. We are talking about a 3 cylinder 4000 here not the older 4 cylinder. One parts manual covers both models if you get real serious about it.
