Order Ford 3000 Parts Online
Noise from hydr. pump 3000 Diesel
Asbjorn
06-13-2004 14:46:37
Hi
After 3-4 days my hydr.pump looses prime and the pump make some ratteling noises until the load is lifted. After some bleeding it works fine. Will lift 600 kg easy.
Any ideas?
Thanks
txblu
06-14-2004 05:47:34
 Re: Noise from hydr. pump 3000 Diesel in reply to Asbjorn, 06-13-2004 14:46:37
Then what happens. Does it go back to rattling requiring bleeding? Sucking air somewhere if it is.
Mark
Lincoln
06-15-2004 21:30:32
 Re: Re: Noise from hydr. pump 3000 Diesel in reply to txblu, 06-14-2004 05:47:34
My 641 was doing the same thing same noise. Just found out this past weekend what the noise was. It was the drive gear for the hydraulic pump, it had worn all the teeth off. Have to split the tractor to R&R. If its the same as mine you can remove the pump to see the gear, may also start tractor to see if noise is gone with it removed.
