Order Ford 2000 Parts Online
2000 radius rod
Bill
06-13-2004 15:33:26
This tractor that I am working on has a broken radius rod. It cracked right where it goes from a tube form to solid steel joint that connects it to the axle. I want to remove it so I can clean it up and get a nice weld all the way around and maybe even a bit of reinforcing too. I haven't put to much time into it yet but I got the nut off the bottom at the axle but have not been able to get the bolt out yet. Any suggestions besides a bigger hammer and a torch? Thanks, Bill.
TimK
06-14-2004 08:50:16
 Re: 2000 radius rod in reply to Bill , 06-13-2004 15:33:26
FWIW: As long as you have things apart, you may want to check the pivot pin for wear. If that pin and the bushing it sits in are really worn, it places that much more pressure on the radius rods to break again.
Matt
06-14-2004 06:16:34
I'm in the process of restoring an 861 and used a ball-joint tool to remove my radius rod's. worked very nice, poped them right out.
Tom in TN
06-13-2004 21:30:35
Bill,
Both of the radius rods on my 2000 have been broken in the past. One of them has been broken twice. You are absolutely right about removing the bolt from the axle. You simply need a bigger hammer and a good punch. The bolt is undoubtedly rusted into the axle and just needs a little persuasion.
Good luck on removing it.
Tom in TN
Bill
06-14-2004 08:12:32
 Re: Re: 2000 radius rod in reply to Tom in TN, 06-13-2004 21:30:35
Thanks for the help, I will get back on it. I WD40'd everything and lossened the nut past the end of the bolt a little and beat it with a sledge hammer until it started to mess up the threads. Time for the torch. Thanks again, Bill.
