Order Ford 3000 Parts Online
Stuck pin on a 3000
AJ in VA
06-14-2004 11:45:02
I have a '66 3000 and I want to replace the bracket that holds the center link to the tractor, because the bracket is broken. How do I get the roll pin out that is holding that bracket to the tractor. I'm afraid to hit it to hard, because I could break the ears on the tranny that holds the bracket for the center link. It is about an 1 1/4 inches dia.. I can't move it even after oiling it for days and tapping on it with a hammer and punch.
sawwas
06-18-2004 09:46:22
 Re: Stuck pin on a 3000 in reply to AJ in VA, 06-14-2004 11:45:02
We took a rear wheel off so we could get a good drift pin and a good swing with a good hammer to get ours out. Don't remember if we applided heat, but we did remove a rear wheel.
RogerC
06-14-2004 15:34:29
In many instances it takes an ample application of heat to help loosen the 30-plus years of rust.
Tom in WA.
06-15-2004 07:58:02
 Re: Re: Stuck pin on a 3000 in reply to RogerC, 06-14-2004 15:34:29
I have exactly the same problem on my Ford 850. I have been advised by two long tractor mechanics. One said to heat the pin to a dull red then cool it completely with a garden hose which will make it shrink a bit. Then drift it out. The other said heat the tranny housing and drift it out while the housing is hot. I haven't done either yet! Still thinking it over.
jc
06-15-2004 13:31:41
 Re: Re: Re: Stuck pin on a 3000 in reply to Tom in WA., 06-15-2004 07:58:02
Trying to do the same operation. Asked some shadetrees yesterday about heating the cast and they said it would be OK. Still nervous. Have you noticed the hole in the center of the casting above the pin? What is it for? I have been soaking the pin with blaster for a week and the hole is dry each time I go back.
Tom in WA.
06-16-2004 07:18:28
 Re: Re: Re: Re: Stuck pin on a 3000 in reply to jc, 06-15-2004 13:31:41
jc, I don't know what the purpose of the hole is but I don't think it opens into anything. My parts manual shows the hole but makes no reference to what it is for. I think I'm going to try heating the casting with a "rosebud" tip on the torch to spread the flame and heat it quickly.
