850: RPM bounce
Austin
04-23-2001 18:16:04
My 850 has a regular "lurch" in the RPM which results in the rpm doing a regular back and forth between 900 rpm and 1080 rpm (or thereabouts). If I increase the throttle a bit it will bounce in a regular fashion between 1000 and 1200. If I increase the rpm to a little over 1200 it runs smoothly without the up and down. This all happens with the tractor in neutral but if I'm in 1st gear at low throttle settings it does the same up and down. Also, if I put the throttle to its lowest setting the engine dies. Do I have a regulator problem, a carb problem or what?
Thanks for the help.
JHunt
04-24-2001 22:33:44
 Re: 850: RPM bounce in reply to Austin, 04-23-2001 18:16:04
There's a chance a faulty distributor centrifugal advance could be causing it. Take you cap off and lightly turn the rotor, it should turn a little and spring back to the original position when you let go of it. If it doesn't snap back the springs are broken in the advance and are letting your timing fluctuate until there is enough centrifugal force to keep them out all the way.
ErnieD
04-24-2001 14:58:22
How low a rpm are you trying to idle at? You soeak of carb so I assume gas fuel. The book says 475 at operating temperature.
Check for binding linkage, worn throttle shaft allowing air leakage.
Drain carb body (plug in bottom) to preclude water or crud.
With fresh gas adjust mixture, (check by applying a little choke, does the hunting go away?
walt
04-23-2001 19:01:08
Sounds more like governor linkage, and carb adjustment..
