Governor seems to be working fine. fuel flow into carb is fine. New points and gap set 1 day old. New Condensor 1 day old New Plugs 1 day old Relatively new regulator less than 100 hours on it New Terminal block New SwitchIt sputters and lurches at high rpm and in highest gears at almost full throttle. Low idle and low gear it runs great. I ran her hot for about an hour. Shut her off and let her sit for 40 minutes. Went outside to restart her and she wouldn't cath fire. Plumes of grey exhaust sputtering out of the exhaust, but would not fire up. Let her sit til cool another half hour, cranked on her and she fired up after some sputters and weak false starts, then finally she started...turned distributor cap about 1/8" to get her to really even out and purr. WHat's the problem you think given that she sputteres at high RPMs in high gear and I then have to monkey with the choke to keep her from sputtering and stalling out...and won't start when hot (now)? Hel;p please my chores are stacking up and I would really like to get through this problem before my woman starts on my case. bob
