Order Ford 640 Parts Online
Wiring Diagram for Ford 5640
Al
07-08-2004 12:03:16
Hello, I am interested in obtaining a wiring diagram for a Ford 5640 tractor. The tractor only has 25 hours on it, but the air conditioner will not work. If you hot wire it, the compressor will kick in, but for some reason it is not getting any power otherwise. It is full of gas so the problem is somewhere else. Please pass along any information you have about what the problem might be or where to obtain a wiring diagram for the air condition.
Regards,
Gary H.
07-08-2004 20:50:58
 Re: Wiring Diagram for Ford 5640 in reply to Al, 07-08-2004 12:03:16
There is a little black box up in the top of the cab. I've had a few of them fail. It's located on the left hand side. It's not a cheap item. Hope this helps. Gary
RickB
07-08-2004 16:46:37
The only place you will find an accurate wiring schematic for your tractor is in the service manual. 800-635-4913 is the number to call to order yours. 40564003 is the part number for the electrical section, about $20. 40564061 is the complete repair manual, about $150.
