hydraulic lift on 641
Al
07-11-2004 19:41:26
Purchased 641 tractor,had water in system. I changed all fluids but can only get arms to raise about ten inch's.Would appericate any help.
. Thank You
Dave H (NY)
07-12-2004 05:10:07
 Re: hydraulic lift on 641 in reply to Al, 07-11-2004 19:41:26
If the lift is only going a few inches it is most likely an adjustment issue and cam follower pin. Contact Zane on this board wzsherman@aol.com he has a book and feeler gauge for the hundred series that he sells for a reasonable price and it should do the trick for you, I had the same problem with my 860 when I bought it and after following Zanes book it works perfectly now. Good luck and post back so we know how you are makeing out. Good luck.
