Order Ford 3000 Parts Online
3000 gas engine problem
Jim
04-27-2001 04:25:43
Recently, my tractor has developed a problem. It starts and runs fine, but when I put a load on it, the engine starts misses for a couple seconds and then starts to produce some power, but still not up to normal standards. I haven't done any work to it recently, but have been using it quite a bit. There are no other signs of a problem with the engine. If I had to guess, I would say its ignition system related (points? timing advance?), but haven't been able to spend any time looking into it yet. Any ideas of where to start?
Thanks,
Jim
texadian
04-27-2001 13:00:57
 Re: 3000 gas engine problem in reply to Jim, 04-27-2001 04:25:43
Jim, I would check the vacuum operated accelerator pump piston in the carb; possibly stuck, possibly some dirt in the pump inlet valve.
Of course, I'd always tune up the ignition system first, then go after the fuel system.
These engines always had a little tendency to bark while the governor was "opening up" the carb. The water heated inlet manifold does not heat up as much as an exhaust heated inlet manifold.
