Order Ford 3000 Parts Online
Front loder Dexta / 3000
Asbjorn
07-26-2004 16:55:51
Hello
A quick question, would a front loader from a dexta fit a 3000???
Thanks !
WayneB
07-27-2004 05:40:31
 Re: Front loder Dexta / 3000 in reply to Asbjorn, 07-26-2004 16:55:51
With modifications, or bracket removal / change. I just pulled a Wagner WF3 loader off my Dexta, which was designed to fit 8N / 800 series. I made a bracket to fit up front between the loader and front engine load mount behind pivot pin.
Since the Dexta has connected mud step plates to fenders, and the WF3 loader mounted on top of the axle, with fender removal/replace, original design would not allow feet plates. I modified the rear wings to mount at the bottom, and neither fenders or feet plates required removal.
I understand that a loader which fit 800 series would also fit 2000/3000 Ford.
So all things said, with modifications or simple braket changes. YES. The loader could be made fit. The tractors are very similar in design.
Wayne
