850 Hydraulic Check Valve
Al
07-29-2004 16:10:44
I am trying to get stop my hydralics from bobbing. I have the check valve out and the contact pattern with the ball is not uniform. If I coat the seat with magic marker and then rub the ball arround, the contact pattern varies.At one point it gets thin and close to the edge. No obvious nicks or scratches. The ball also has some wear marks but they are shallow. I was thinking of replacing the ball and laping the valve chamfer in with compound on another ball. If I knew the valve would fix the problem, I would replace the valve and may later. Anyone ever lap this valve's seat with success.
