Order Ford 4000 Parts Online
FORD 4000
bob morey
08-14-2004 23:00:46
How do i determine the exact model # of my 69 industrial 4000 series tractor with backhoe set up? It has 3 cylinder diesel motor. THANKS
sotxbill
08-15-2004 08:04:10
 Re: FORD 4000 in reply to bob morey, 08-14-2004 23:00:46
look for the model number on the flat spot behind the starter on the trans.. there will be 3 numbers there,, one will be a model, one a serial number and one is a production date code..
but its probably a 4400 or a 4500... look at the front axle.. if its adjustable width axle, its an all purpose 4100.. if its a fixed I beam, its a 4400,, if its a steel covered structure-beam with king pins instead of spindles,,its a 4500...
btw.. the first is rated 3000 lbs, the second is rated 5000lbs and the last is rated 7000lbs...
hth.. bill
