Order Ford 4000 Parts Online
4000 S-O-S bearing
David Tiefenbru
04-30-2001 20:17:47
I discovered that the front input shaft bearing is not a standard 6307. It is a BCA N307. Same bore and O.D., but it is only 17+ mm thick and the 6307 is 21mm thick.
Ford says No Longer Serviced, local big bearing house shows that the manufacturer has big minimum order and long lead time for what they consider a custom part.
Anyone know of a source for a new bearing?
I could turn the shaft to allow for the difference, or use my freind's Arter Grinder (rotary table) to thin out the 6307.
Thank you,
Dave
David Tiefenbrunn
04-30-2001 20:20:08
 Re: 4000 S-O-S bearing in reply to David Tiefenbrunn, 04-30-2001 20:17:47
I found the part number: C5NN7025A
Dave
