Order Ford 600 Parts Online
Ford 600 - 1954 - 6 volt: Starting problems
Brad Land
08-27-2004 12:33:27
Engine will turn over but can't get fire to plugs. Replaced wiring, distributer kit, coil, regulator, terminal block, ignition switch, and battery. I have 6 volts going to coil. Still can't get anything to spark. Any suggestions? Thanks.
Jim.UT
08-27-2004 16:33:06
 Re: Ford 600 - 1954 - 6 volt: Starting problems in reply to Brad Land, 08-27-2004 12:33:27
Check condition of the copper strap inside the distributor that carries current to the points. Sometimes it can get broken and go unnoticed.
Also, condensors are cheap and sometimes are bad out of the box. Try another condensor.
RICKWI
08-27-2004 15:15:24
Does the distributor shaft turn?
George H
08-27-2004 17:12:45
 Re: Ford 600 - 1954 - 6 volt: Starting problems in reply to RICKWI, 08-27-2004 15:15:24
Also check where the coil primary wire connects to the distributor. There's an insulator inside the distributor that prevents the wire/fitting from grounding ahead of the points/
condensor. I haven't had to deal with it, but from reading along here, it's not unusual for the insulator to break.
