Order Ford 8N Parts Online
Ford 600 front end loader, will it fit on a Ford 8N?
BNewman
05-01-2001 19:26:04
Does any one know if a front end loader that came of a Ford 600 will fit a Ford 8N? Thanks to all that reply.
Bryan
Roland Jackson
05-02-2001 13:27:46
 Re: Ford 600 front end loader, will it fit on a Ford 8N? in reply to BNewman, 05-01-2001 19:26:04
Brian, Horseman is right in that the 600 series is longer than a 8N and you will have to make an adjustment to the rear mounting points. Sometimes that is as easy as drilling new mounting holes in the brackets. I am getting a Wagner loader ready to mount on an 8N. This loader has several "owner Made" mounting holes as this loader has been on several different models including an 800. I will be painting the 8N in the morning or when ever the weather will allow me to. Then after installing power steering, I will mount the loader.
I will have pictures in photo point under the email name ronj@arn.net in the next few days of the 8N, the installation of the power steering and the installation of the loader.
Holler if I can help you!
Horseman
05-02-2001 05:23:13
Hey bryan I dont think it will unless it has mount's that are about six inches shorter in the rear attach points. I say this only because I just took my old loader off that used to be on a N series and it had welded on extensions to fit my 841D (same size as 600). good luck WRP
