Order Ford NAA Parts Online
19-2 front blade fit Jubilee?
Al L. in Wisc.
08-31-2004 06:15:23
Will a Dearborn 19-2 front blade fit a Jubilee? Also, any Jubilee for sale in southwestern Wisconsin? Thanks in advance.
forworkma
09-01-2004 04:44:06
 Re: 19-2 front blade fit Jubilee? in reply to Al L. in Wisc., 08-31-2004 06:15:23
The Ford 19-2 is the Angle Dozer and it is designed for the NAA and 600-800 series.
CRock
08-31-2004 08:49:44
It might, it dependes on how much longer a Jubilee is than an 8N. I bought a front blade a few years ago that fit my 8N. I sold the 8N and bought an 861. The 861 is a longer tractor so, when mounting the unit, the blade only cleared the front wheels by 3 inches and therefore I could not angle it. I solved the problem by cutting off and reattaching the rear brackets so that the unit was moved forward on the tractor. I then added a hydraulic cylinder bracket to an old bumper and lift the blade with a cylinder rather that the lift arms. It also allows me to carry a three point blade on the rear. I can move snow like a professional. By the way, I am also in SW Wis. I would be happy to show you what I did.
Al L. in Wisc.
08-31-2004 20:27:23
 Re: 19-2 front blade fit Jubilee? in reply to CRock, 08-31-2004 08:49:44
Sounds like you are talented. I don't know how to weld, etc. Yes, I would like to see your plow, do you have pictures to post here? Thanks.
