Order Ford NAA Parts Online
Questions about Ford Jubilee
BB
09-02-2004 19:32:46
I looked at what I thought was a ford jubilee today. Where is the serial plate on this tractor? Also was the jubilee 3 foward and 1 reverse? The one I looked at was. The tractor needed paint but ran with no smoke and lift worked excellent. All gages worked except Tach. but fellow said engine was rebuilt 3 years ago and hasnt been used much. Steering was very tight. All I can say that the tractor needed was a muffler. The guy had bushhog, boompole, scafier,2bootomplow,angle scrape blade, and cultivater that came with the Tractor. The fellow wants $3,000.00 for everything. Is this a good buy? I have several but dont have a ford and dont really need it but if its a good buy I would probally jump on it. Thanks and sorry for the long post.
BB
RWK in WI
09-03-2004 05:22:09
 Re: Questions about Ford Jubilee in reply to BB, 09-02-2004 19:32:46
The model and serial numbers are hand stamped on the flat area of the transmission on the left side just above the starter. A 3 speed can't be a Jubilee.
It could be a later 650 / 651 /660 / 771, 850 / 851 / 860 / 861 with a 5 speed transmission and with the unusual up and down shift pattern you are not feeling the two gears at the center point.
Can you post a picture of the tractor?
Geo in SD
09-03-2004 05:00:31
If the tractor you looked at had three forward gears and reverse, it wasn't no Jubilee. They have four forward and a reverse. The 9N and 2N's had a three speed trans, but they are older.
Now, you say it has a tach, and the older Fords didn't have a tach until 1950. Makes me think you are looking at a Ferguson.
John A (TX)
09-02-2004 23:18:40
The link below might be a help on the ID part of your question.
As for its value, a few thoughts: The lack of a new paint job might be a plus. You get to see what would otherwise be covered up by new paint! I"m sure no expert, but for what you"re describing (runs good, hydraulics are good, several attachments included), $3000 sounds like a pretty good price.
HTH
~ja
