Ford 1300 Loader?
Andrew Abate
09-13-2004 13:24:25
Does anyone know of an aftermarket loader for the 1300? I have a 4wd with manual steering. I don't want to lift mountains, just move some dirt. Also, does anyone know how to rebuild the bearing housing on a 900 mower deck. I have one that is throwing sparks.
Thanks!
WayneB
09-17-2004 11:36:50
 Re: Ford 1300 Loader? in reply to Andrew Abate, 09-13-2004 13:24:25
I have a Ford 1100 4WD. I use a 60's vintage ford rear scoop. Reason for pin-location conversion is the regular location for the class I pins will pull the front end off the ground with a shovel full of dirt. Moved them back about 8" and I can fill it completely and still drive with no weight on front, and it still dumps.
Converted the scoop hitch pin locations with weld on extensions (cost me $80 total) and it moves more dirt than a FEL, for less cost. I can scoop forward or rearward. But it isn't as trendy as a FEL.
Wayne
paul
09-15-2004 07:06:13
There are so many loader manufaturers these days, they all make small models for your tractor. I don't know any specifics so I hate to metion a brand, but you'll find a dozen or more.
Fix it now! Waiting & parts cost will SKYROCKET! Seeing sparks means it's wearing out shaft, housing, and more.
--->Paul
