Yes it is
Bern
09-15-2004 16:04:04
Yes, it is normal. Take it from someone who's worked on more of those things than he cares to remember. It's not right, but it's normal.
See my posts below re. the 6000 for more info.
texas3000
09-15-2004 22:51:23
 One more for you Bern... in reply to Bern, 09-15-2004 16:04:04
Thanks Bern. While your at it, can you point me toward the fill level plug for the rear end? I resealed the left axle hub and drained about 2 gallons of oil in the proccess. I was told the oil level plug was on the front right side under the seat (square head plug). I pulled the plug out and was met with a gush of oil. Could it have been way too full or am I in the wrong place?
Bern
09-16-2004 08:19:24
 Re: One more for you Bern... in reply to texas3000, 09-15-2004 22:51:23
Yes, it is usually a square headed plug. It should also be 1/4" NPT pipe thread. Sometimes I have seen the factory install an allen head plug though. It"s not much higher than the level of the floorboard.
