No script fenders available for 1955 850?
apekim
10-07-2004 06:15:16
I was looking for a pair of rear fenders for the early hundred series tractors. They look like the Jubilee fenders that are smooth with the Ford script pressed into them. They might even be the same part as the jubilee fenders, but I don't know since I never had both in front of me to compare.
As far as aftermarkt fenders go, I don't recall ever seeing anything advertised for the early hundreds, except the later dished type that will fit early tractors. But they look nothing like the original. The 8n and 9n repro fenders have the script, but they appear to be smaller.
Mike
Richard H.
10-07-2004 19:18:55
 Re: No script fenders available for 1955 850? in reply to apekim, 10-07-2004 06:15:16
Yes you can find them ,With or without script.I believe the fender with mount & script is about $170.00. Richard P.S. Without script is 99.00
Tom in WA.
10-07-2004 21:36:19
 Re: No script fenders available for 1955 850? in reply to Richard H., 10-07-2004 19:18:55
Richard I've been looking for script fenders for my 850. Can you tell me who has them? Thanks
Jim.UT
10-07-2004 09:08:16
Ah, fenders! One of my favorite topics! I love it when people pander to my obsessions.
The Jubilee fenders are (as far as I know) the same as the late 8N fenders. The hundred series fenders are larger. They wrap up and over the top of the tire more than the Jubilee fenders. They do have Ford script on them. There is no one that I know of making reproduction hundred series fenders. So the junkyard is your only source for finding replacement fenders. Finding cherry ones is a real challenge.
This compounded by the fact that the 1955 fenders are unique and different from the '56 and '57 fenders. This is only a concern if you are nitpicky about originality and correctness. The difference lies in the support system and is not really a glaring difference to the casual observer. The '55 fender skins are supported with a piece of flatstock steel that is bent so that it loops around the perimeter of the fender. This is the same system used on the 8N and Jubilee. In '56 and '57 that system was replaced with one that used three beefy braces branching up from the mounting base to support the fender skin. My guess is that after '55 there were complaints about vibration and the Ford engineers decided the bigger skins needed more support. The skins themselves are the same shape and size. Still there's no one making reproduction hundred series fenders. You can find repop x01 fenders pretty readily. Those are the flatter shaped fenders with the kidney shaped indent in the middle. Original fenders had Ford script. A lot of the repops do not.
Don M
10-07-2004 10:42:09
 Re: No script fenders available for 1955 850? in reply to Jim.UT, 10-07-2004 09:08:16
Apparently the 01 fenders had some sort of problem with the way they were attached because my 641 has had a piece of angle iron attached between the two fenders. They are definitely stable and there is work light also bolted to the cross member. I've seen other 01s with loose wobbly fenders too.
Jim.UT
10-07-2004 11:09:08
 Re: No script fenders available for 1955 850? in reply to Don M, 10-07-2004 10:42:09
I've never owned an x01 series tractor so I don't have first hand experience. But from just looking at them they do seem like they'd be more flimsy and prone to vibration. It looks like the designers were intending that the kidney shaped dish in the middle of the skin would suffice to give the fender enough rigidity to last. Then they cut way back on the support given by the mounting system. It seems like a recipe for metal fatigue at the base where the skin is connected to the base.
