Order Ford 4000 Parts Online
4000 industrial steering
Alan Hughes
10-16-2004 10:55:13
We have a 4000 industrial (4 cyl gas) on which the power steering is not functioning well at all. The power steering pump is putting out 1000 psi of pressure before the drive belt slips but we are only getting 150 psi at the steering cylinder. On dissasembly the steering valve appears to be in good shape but it still will not function like it should. We are to the point that we think we should replace the steering valve but it is a part that is NLA through Ford.
Any ideas on where we could find one, what else might fit it, or what other course of action we should pursue???
The numbers on the bell housing are as follows:
41405
*53939
Thanks in advance,
Alan
Roland Jackson
10-17-2004 16:55:59
 Re: 4000 industrial steering in reply to Alan Hughes, 10-16-2004 10:55:13
Hi Alan,
I think all you need to do is adjust the valve. Real easy to do. I am in the power steering business and I work with those cylinders all the time. I would be happy to walk you through it. I would need more information, so you can email me or you could call me at 620-357-6546.
