Need help with loader removal
Bill Boquist
10-18-2004 18:04:21
I have removed a Wagner loader from my tractor except for the flange and shaft that attach the crank to the front pump. I have removed the four bolts from the flange so that it is sitting loose in front of the engine, but the shaft is still attached to it. I need to separate them so that I can lift the flange out and slide the shaft forward. How are they connected? How should I separate them?
old
10-18-2004 20:53:19
 Re: Need help with loader removal in reply to Bill Boquist, 10-18-2004 18:04:21
The one I have you first remove the pump and then the shaft will slide right out. On my loader its just a splined shaft that goes in to a drive hub bolted to the crank pully
jim barlow
10-25-2004 04:15:53
 Re: Need help with loader removal in reply to old, 10-18-2004 20:53:19
Some of them are left hand threaded in.
