Replacement hydraulic cyls on loader
Beststash
11-01-2004 14:40:04
I have a Ford Industrial Loader (pieces - not sure of the model but very similar to 730,735,etc.) that came with my recently purchased Ford 3000. I am missing the bucket (tilt) cylinders and bucket. I have looked for similar replacement cylinders at booth Northern Tools and Surplus Center - Surplus Center comes real close to an exact match with the exception of the base end size. The orig (I looked at another loader) is 30" retracted and 20" stroke - the base end needs to be no more than 2" - the outside clevis end of the Surplus Center cyls is 2.62" - the only thing I can think of is to maybe straddle the base on loader frame....one ear inside and the other outside and use a spacer to keep from moving - would that work?? Look like crap?? Any suggestions??
Beststash
11-06-2004 14:24:38
 Re: Replacement hydraulic cyls on loader in reply to Beststash, 11-01-2004 14:40:04
Thanks to everyone for the responses....I called Surplus Center and sure enough they were able to find me a replacement that will work - 2 for about $300 including shipping - I don't think that I could do better than that - it will be interesting to see how much it will cost to rebuild the "lift" cylinders if necessary.
Thanks again everyone!!! Great Forum.
Steve_ne
11-02-2004 05:58:59
Have you given them a call. Sometimes not everything they have is on there web site and you may get lucky.
alg
11-02-2004 02:17:45
look up surplus center on the web,best prices around.
txblu
11-01-2004 17:36:24
Also, ASC has lots of cylinders.
On the same thought. Had a JD with a loader and the loader had 4 hookup points; 2 hard points (on the lift arms) and the two cylinder rams. Was almost impossible to connect alone.
Tore up one cylinder one day and decided I wasn't going to pay the $350 JD wanted for a new one. Took the remaining one and relocated at the center of the loader with fabricated mounting brackets . Painted it up nice and green and it didn't look bad at all. Amazing how much easier I could attach it.
HTH.
Mark
Hurley J. D.
11-01-2004 17:01:12
Link
Check these guys out
