Order Ford 4000 Parts Online
4000 industrial power steering parts
Alan Hughes
11-02-2004 14:34:20
I am working on a 4000 industrial (4cyl gas) with the single cylinder power steering system. I am looking for a steering valve for the above tractor and have not been able to find one yet. Does any one have any suggestions?
Thanks in advance
Alan
Shawn Keenan
03-24-2005 17:47:52
 Re: 4000 industrial power steering parts in reply to Alan Hughes, 11-02-2004 14:34:20
Hi Alan, If you still need the Steering value for the 4140 HD Industrial tractor please contact me. Thanks, Shawn
Scott PA
11-02-2004 18:16:34
Do you have a 1960-1962 4040 with the valve built into the cylinder and cables to control or do you have a 1962-1965 4140 with tubes and hoses going from the gearbox to the cylinder?
Alan Hughes
11-03-2004 07:30:14
 Re: 4000 industrial power steering parts in reply to Scott PA, 11-02-2004 18:16:34
We have the 62-65 with the valve ontop of the steering gearbox and hoses running forward to the steering cylinder. Not the earlier one with the cable operated system.
Alan
Scott PA
11-03-2004 18:07:59
 Re: 4000 industrial power steering parts in reply to Alan Hughes, 11-03-2004 07:30:14
Do you need the valve block in the column or the relief valve in the pump?
Alan Hughes
11-04-2004 16:14:28
 Re: 4000 industrial power steering parts in reply to Scott PA, 11-03-2004 18:07:59
I need the valve block in the column that is directly under the steering wheel. I think I should also mention that this is one of the single cylinder steering systems so there should only be 4 hoses going into or out of the vaalve block.
Thanks,
Alan
If you feel it would make things easier, E-mail me your phone number and I'll give you a call
