Front Mount Pump for Ford Loader
Beststash
11-13-2004 14:19:15
I recently bought a Ford 3000 with frame for Ford 730 (or equiv) loader. I am debating whether to use the on-board hydraulics or go for the front pump.
After reading this forum - it seems that most recommended the front mounted pump - does anyone have experience using the on-board hydraulics??
If I go the front pump method - any suggestions on where to find a pump and also what size (gpm) is recommended. Going this route will mean that I will need to use the loader reservoir for hydraulic oil and I guess a filter, etc.
Obviously it would be much easier to just use a lift cover manifold on tractor but not sure how it may work.
Any help appreciated!!
Mike Coleman
11-17-2004 18:17:28
 Re: Front Mount Pump for Ford Loader in reply to Beststash, 11-13-2004 14:19:15
That loader came with a 9 or 13 GPM.
I have a 735 loader and just rebuilt the pump ($170 for the kit) from Ford. The problem is that it keeps reliefing @ 2200 PSI and overheats the oil and tractor unless you are doing a lot of loading/ unloading.
I am considering plumbing mine into the Tractor hydro.
If I had known it would be so expensive I think you would do better with a 2 stage pump (barnes) from Northern Hydraulics, you would have to jig up a shaft coupling (McMaster Carr) and some how I would reccomend putting in an electric clutch to stop the pumnp when not needed.
Just a thought
Mike
Beststash
11-18-2004 07:08:05
 Re: Front Mount Pump for Ford Loader in reply to Mike Coleman, 11-17-2004 18:17:28
Thanks Mike for your insight. After checking onto the cost, I am considering using the tractor hydraulics. I will not be using the loader much and hope its speed is OK. If not, I will only be out about $100 for a manifold - then I will pursue the front pump solution. I visited a neighbor with a similar loader - it was very fast, maybe a little too fast (jerky). Anyway - I"ll just have to see. It is my understanding that the Ford 3000 has a 5.3 GPM pump.
Dave1
11-14-2004 07:24:07
For the pump, bracket, and remote filter housing I am asking $250. I am located on Grand Island, New York .If interested I can send you pictures if you provide me with your Email. Thanks, Dave
Beststash
11-14-2004 08:26:50
 Re: Front Mount Pump for Ford Loader in reply to Dave1, 11-14-2004 07:24:07
Dave,
I am interested....can you send photos to dtatum@gvtc.com
I am in Texas - would you be willing to ship??
Dave1
11-13-2004 17:06:24
I have a massey 240 with a loader that is plumbed into the tractor hydraulics, It operates much slower than a independent pump but, has the same lifting capacity. I have a front pump and mounting frame with a remote filter housing for a Ford 3000 I acquired in buy out deal, let me know if you are interested. Dave
Beststash
11-13-2004 19:21:53
 Re: Front Mount Pump for Ford Loader in reply to Dave1, 11-13-2004 17:06:24
Dave,
I'm interested - let me know the details.
Dave_N_Ga
11-13-2004 18:10:28
Dave1,
I may be intersted in the frame, pump, and filter. Where ya located and whatcha want for it?
Dave
