Order Ford NAA Parts Online
1953 JUBILEE ENGINE SLEEVES
BUS
05-11-2001 08:38:50
I HAVE A 1953 JUBILEE IM REBULIDING THE ENGINE IN FRAME. COULD ANY ONE TELL ME THE BEST WAY TO GET THE SLEEVES OUT? I HAVE ONE THAT IS BAD BUT I LIKE TO CHANGE ALL OF THEM. THANKS
Travis Shuman
05-11-2001 16:02:29
 Re: 1953 JUBILEE ENGINE SLEEVES in reply to BUS, 05-11-2001 08:38:50
I asked the same question a few months back. The one that worked for me was putting a couple of hot pass welds down the sleeves. I think I use a 7018. I did about 5 or 6 welds down the sleeves. I let it cool for just a second then got a brass punch & still had to beat them out. It worked fine for me.
Chris
05-11-2001 19:01:43
 Re: Re: 1953 JUBILEE ENGINE SLEEVES in reply to Travis Shuman, 05-11-2001 16:02:29
Protect your crankshaft if you do it that way! Don't spatter it with weld. A sleeve puller will often work without the weld trick.
