1210 Ford compact
9n141
11-14-2004 19:50:30
Does anyone own or have info ? Thank you. BURT.
WayneB
11-15-2004 11:26:35
 Re: 1210 Ford compact in reply to 9n141, 11-14-2004 19:50:30
I own a Ford 1100 4x4 which is a similar size. I've owned it 14 years, and other than oil/filter changes, a couple of light bulbs, and the rubbers under tie-rod ends: ZERO MAINTENANCE. I've put about 750 hours on it. I use it on my farm to mow with a 5' finish mower versus my 35HP tractor. More maneuverable and just as fast except in the high stuff where I should use a bush-hog anyway.
These little critters are too light to use without 4WD, but for 'boomer-type' chores, they are a little work horse.
All day long on less than 2 gallons diesel.
Wayne
paul
11-15-2004 07:33:23
I bid on one at an auction once, with an aftermarket loader & belly mower.
Didn't get it, got a 1720 a year later.
Don't know if this is the info you wanted? :)
--->Paul
TomTX
11-15-2004 06:34:43
Burt, your post is rather vague. Info available at tractortips.com, have you tried that?
9n141
11-15-2004 14:38:46
 Re: 1210 Ford compact in reply to TomTX, 11-15-2004 06:34:43
Sorry, I was thinking of buying one. 250 hours stored in heated garage, always serviced by the dealer. Looks, runs good, 4 way front blade (ford) joy stick control. Hydr. 4x4, ROPS, What is HP , the value, weak points, available parts, etc.????? ????? BURT.
