Order Ford 3000 Parts Online
1972 ford 3000 thermostart operation / testing
Bob B
11-16-2004 18:07:41
I recently purchased a ford 3000 diesel tractor.
my questions are; how do I verify the manifold
heater is working ? {I suspect it is not]
There is 12 volts at the connector in "heat"
position. The shop manual I have does'nt go
into detail about testing the unit, continuity,
etc. Any suggestions would be appreciated thanks Bob
Bob B
11-23-2004 16:23:27
 Re: 1972 ford 3000 thermostart operation / testi in reply to Bob B, 11-16-2004 18:07:41
thanks for your responses, thermostart works
exactly as you described. Now that I see how
it works I know how to use it. Thanks again, Bob B
DanaNC
11-16-2004 19:13:35
If you have checked to make sure you have battery voltage at the thermostart plug then I would remove the intake hose and look inside the intake manifold at the coil while holding the switch to the heat position the coil should glow. If it doesn't it should be replaced. Also make sure the fuel tube conected to it is not plugged an is that it has fuel at the plug. HTH Dana
txblu
11-17-2004 07:14:51
 Re: 1972 ford 3000 thermostart operation / testi in reply to DanaNC, 11-16-2004 19:13:35
Yes to above including removing the tube and running the engine to wash out the line. Don't forget to look back into the device for more crud. If you install a new one as I did the plugging problem is solved.
Then when you fire it up (hold the ign switch in heat position), the coil should glow and after a minute or two, the diesel plug will unseat and allow diesel to drip on the coil. This diesel catches fire when dropping on the coil.
Then when you turn the stitch on over to start, the engine sucks these "great balls of fire".(Jerry Lee Lewis) into the combustion chamber and bango!!!you're in business.
Mark
