Order Ford 5000 Parts Online
Ford 5000 diesel (236) engine specs, torque specs
Anders
11-21-2004 00:09:56
Looking for engine specs like timming of diesel pump, injector specs, torque specs for whole engine, but mostly the cylinder head. Should the cylinder head be retorqued after a few hours? And to what?
The diesel pump is a minamec pump.
The engine is a Ford 5000, 236 (1972) engine, diesel.
Gary H.
11-22-2004 04:06:57
 Re: Ford 5000 diesel (236) engine specs, torque sp in reply to Anders, 11-21-2004 00:09:56
Same specs either way
Gary H.
11-21-2004 05:51:14
Pump timing is 19 degrees. The manuals will tell you the head torque is 105 ft/lbs , but torque them to 115 ft/lbs. There was a bulletin a long time back dealing with this. Also make sure ALL head bolts have a hardened washer on them.Part # 377490S. As a rule I'll set the intakes at .017"cold on the intakes and .020" cold on the exhaust. It wouldn't hurt to retorque the head and reset the valves after 20-25 hrs.
anders
11-22-2004 00:04:00
 Re: Ford 5000 diesel (236) engine specs, torque sp in reply to Gary H., 11-21-2004 05:51:14
Of course I mean the 256 engine, typo.....
