Order Ford 4000 Parts Online
HELP!!! 4000 HD Industrial Power Steering
Alan in WI
11-22-2004 15:25:39
We are still looking for a steering valve for a 1964 Ford 4000 HD Industrial (model# 41405, sn. 539xx, 4 cyl. gas). This is one or the later ones that has the steering valve under the steering wheel, on top of the steering gearbox.
(Not the cable operated one up on the steering cylinder.) The steering valve that we need operates only one steering cylinder and has 4 ports that take banjo style fittings. the gearbox below it has only one steering arm on the left hand side of the tractor. The p.n. for the valve assembly is C0NN3A730B. I believe the latest steering valves operated two steering cylinders and have six ports which is NOT the style that we need.
Any help on who, where, or how I might be able to find a valve or a complete valve and gearbox assembly would be greatly appreciated. I've tried many salvage yards already and haven't found many places that even know what I'm talking about.
Thanks in advance,
Alan
larry loy
12-24-2004 00:00:35
 Re: HELP!!! 4000 HD Industrial Power Steering in reply to Alan in WI, 11-22-2004 15:25:39
mac tractor parts in w. silom springs ok has a complete steering just like you are talking about....i have both systems so i no what you need...he priced me the whole system for 750..pump-steering colum-steering arm--every thing to convert from cable steering --don"t know if he will sale just colum
sotxbill
11-22-2004 17:38:35
check with either sparex or a&i products.. one of them carries it new.. but it will be pricey...
hth..bill
Anthony-65
11-23-2004 06:51:03
 Re: HELP!!! 4000 HD Industrial Power Steering in reply to sotxbill, 11-22-2004 17:38:35
Are the orings in the valve body or on the cylinder themselves, or both ?
If I need to change orinmgs on the spools, do yo do that from the top, bottom, or both ?
Thank You for your help.
Anthony-65
11-23-2004 11:49:49
 Re: HELP!!! 4000 HD Industrial Power Steering in reply to Anthony-65, 11-23-2004 06:51:03
Sorry about that, wrong post.
