Order Ford 4000 Parts Online
'71 Ford 4000 PTO brake
Eric
05-14-2001 08:57:52
I have an independent PTO and the brake pad on the PTO seems to be faulty. Do you have to split the tractor to change the pad or what is the process for changing it? TIA
texadian
05-14-2001 13:57:05
 Re: '71 Ford 4000 PTO brake in reply to Eric, 05-14-2001 08:57:52
Eric, Yes, you have to split the tractor. PTO brake is a small arm with a bronze brake pad that bears on the outside of the pto clutch housing. It's applied with a double spring and released with the same oil pressure that engages the clutchpack. After you remove the clutchpack/oil manifold/brake assembly, use a small press or puller to compress the brake springs and remove a retaining snap ring.
Bern
05-14-2001 19:20:26
 Re: Re: '71 Ford 4000 PTO brake in reply to texadian, 05-14-2001 13:57:05
I'm not so sure you'd have to split the tractor to replace it. I know for a fact that I've changed one on a 4610 without splitting the tractor; I went through the top cover opening on that one. Big difference between a 4000 and 4610 is that the 4000 brake is spring applied with the engine off. This spring tension can be relieved through the side access plate.
Ev Hanson
05-14-2001 15:04:24
Great time to check the pto clutch pack, replace the pto oil seal and replace the hidden hyd. oil filter.
