Pump shaft for Davis model 100 loader
Bill Boquist
12-11-2004 19:10:57
Hi, I am getting ready to sell a Davis model 100 loader. I would like to sell it complete, but the previous owner welded the pump shaft to the flange that is connected to the crank, so I will have to cut it to get it out of there. Where can I or the new owner obtain a replacement shaft? I have looked at Walts tractors, but cant tell which pieces will work. Thanks!
jeffmn
12-12-2004 18:08:43
 Re: Pump shaft for Davis model 100 loader in reply to Bill Boquist, 12-11-2004 19:10:57
I picked up the front hydraulic pump shaft and connecting pieces for my davis 102a loader from the New Holland dealer. Its on a 641. They had the stuff in stock. I don"t remember if the shaft came in different lengths or not. That was 2 or 3 years ago.
Bob
12-11-2004 19:53:30
The parts section of THIS site lists pump shafts and drive hubs, but again, I don't know how you'd determine which you need. Perhaps if you called them, they could verify length and diameter, and as long as it is long enough, and the same diameter as your's so it would fit the coupling on your pump, you should be OK.
Bill Boquist
12-16-2004 17:18:19
 Re: Pump shaft for Davis model 100 loader in reply to Bob, 12-11-2004 19:53:30
Thanks to both of you. That helps a lot.
