Order Ford 3000 Parts Online
Checking compression on 3000 diesel
Bart1000
12-23-2004 06:55:24
How do you check the compression on a diesel? Do you need a special gauge that screws into the injector hole after the injector? Do you do it with the engine running while hot, or just turning it over? Thanks for any advice.
txblu
12-23-2004 17:55:36
 Re: Checking compression on 3000 diesel in reply to Bart1000, 12-23-2004 06:55:24
John answered why I don't have a gauge. What's your problem? Maybe we can help without your having to spend the $$$.
Mark
john in la
12-23-2004 08:07:34
Yes you need a special gauge to check a diesel's compression.
A diesel has compression in the 400 to 600 psi range so a gas gauge will not work.
You then need the adapter to fit your injector hole or the glow plug hole per your type of engine.
Cost starts at about $125.00 and goes up with how many different adapters the set comes with.
Bart1000
12-23-2004 08:09:07
 Re: Checking compression on 3000 diesel in reply to john in la, 12-23-2004 08:07:34
Thanks, I think I will just take the tractor to a shop and tell them to check/clean the injectors and check the compression. That sounds easier and probably alot better than i could do!
