Seal Kit for Plessey power steering pump, installe
Anders
12-26-2004 11:56:53
Hi!
I have a C7NN3A674F power steering pump on my Gigantic with a Ford 5000 diesel engine. Need to find a seal kit for this pump. Also need to find some bearings for it also. The bearings should messure
around 17,39 mm inside diameter, around 19mm outside diameter. And the lenght of the bearing is 13,5 mm. These are glide bearings.
Please direct me to a source that has these things. Preferly with a online web shop.
Best regards Anders
greywynd
12-26-2004 20:52:44
 Re: Seal Kit for Plessey power steering pump, inst in reply to Anders, 12-26-2004 11:56:53
Being a toolmaker, I almost instantly recognized those dimensions. If you remeasure in imperial, you should find that it's 3/4" od, 11/16" id. This could be something available at most bearing supply houses...i know our local TSC even has some standard bushing sizes in stock, but i'd doubt that one. Just another possibility for you to check out.
Mark
Anders
12-27-2004 00:11:56
 Re: Seal Kit for Plessey power steering pump, inst in reply to greywynd, 12-26-2004 20:52:44
Thanks, I will check that out. The bearings are indeed imperial size. So a std bearing should proberly fit.
Thnaks.
kyhayman
12-26-2004 16:40:57
Seal kits are pretty easy, regular NH stock item. I keep a spare on the shelf ($56.00). Bearings, I may have a used set, will check tomorrow. Email if interested.
Anders
12-27-2004 00:15:22
 Re: Seal Kit for Plessey power steering pump, inst in reply to kyhayman, 12-26-2004 16:40:57
Seal kit can be found at a New Holland dealer?
I have tried to search the tractor sites for info. But they only list it as seal kit. No mentioning of it fitting the Plessey squre pump. But maybe it does.
Will have to make some calls.
Check the bearings as mine are really bad.. No damage to shafts.
kyhayman
12-27-2004 18:38:10
 Re: Seal Kit for Plessey power steering pump, inst in reply to Anders, 12-27-2004 00:15:22
Please email and I'll reply with a pic of what I've got. They look good and seem to measure to what yours are. Out of a Plessey pump. My emails unmasked.
