hydraulics for loader - corrections
Beststash
12-29-2004 16:18:33
69 Ford 3000 - I went to the Ford dealer today to purchase the manifold that fits on lift cover (pressure in & pressure out). The parts guy there said that I would need an open-center control valve with Power Beyond.... I have open center valve (2 spools) but without PB. Parts guy says I will lose the 3pt functionality if I use with my valve. I was wondering if I might just tap the port on the existing top cover (I do not have the diverter valve on my cover) and then put a "T" on the sump (fill hole), top for fluid, center for loader, and bottom on nipple connected to sump. Two questions - Will this work?? Will I have 3 pt functionality??
If not could I insert a small gate valve (under seat) to turn off when using loader??
Am I making this too complicated???
Beststash
