641 Workmaster Questions
Brad Dale
12-30-2004 17:28:07
I bought this tractor 2 years ago. It had been refurbished nicely. I would like to change oil and fluids. I have an 8N that I am restoring and use 20W50 motor oil and GL 1/90wt in the trans, etc. Would it be ok to use 20W50 in the 641 engine? What should I use in the three reservoirs for trans, diff. and hyds?
Thanks,
Brad Dale/MS Gulf Coast
9n141
12-30-2004 18:55:26
 Re: 641 Workmaster Questions in reply to Brad Dale, 12-30-2004 17:28:07
From the orig. owners man. trans 61/2 US qts. SAE 80 , HYD 8 US QTS. 134 HYD OIL, REAR AXLE 8 US QTS. SAE # 80 note there are 3 drain plugs and 3 filler plugs . BURT.
Geo in SD
12-30-2004 18:53:52
I don't know if it would be necessary to use 20-50 in the engine. If you have a low oil pressure problem, then it wouldn't hurt. I use 10-30 in my 641 and have no problem with oil pressure. I use 20-50 in my 8N, tho, because it has low pressure when hot. In your area, it gets hot in the summer, and it kinda depends on how hard you work it, too. In the hyds, trans, and diffy, I use NH spec 134 oil.
