Order Ford 3000 Parts Online
Tap in to hydraulic line Ford 3000
Asbjorn
01-06-2005 12:08:25
Hi!
I have a 71 Ford 3000 and my question is this:
i want to use my doble acting top link without the selector valve. Can i cut the hydraulic pressure pipe that goes from the pump, take it in to my aux central and use the return from the central to pass the fluid on ?
I have a central that today is feed from the tip connection and the return goes in to the oil filler plug.
Thanks!
Sorry for my writing but im from Norway :)
paul
01-06-2005 18:02:46
 Re: Tap in to hydraulic line Ford 3000 in reply to Asbjorn, 01-06-2005 12:08:25
Generally with open center hydraulic systems you need to use control valves with 'power beyond' and daisy chain them through these special Power Beyond ports.
You cannot just 'T' into the pressure line - that makes a parrellel setup & it doesn't work right. But if you use the right control valves, you can connect them in series as you plan. Here in the USA you look for 'Power Beyond'.
That is as much as I know about hydraulics, hope smarter folks can help you. :)
--->Paul
